Hybrid work has changed secure access from a network problem into a layered security problem. Users connect from offices, homes, hotels and unmanaged networks, often across a mix of SaaS applications, Windows applications, remote desktops and support tools.
The best secure access solutions for hybrid work environments in 2026 do not all solve the same problem. Some protect private application access, some harden Remote Desktop Protocol (RDP), some publish Windows applications , and others support remote troubleshooting. This guide compares the best options by security layer and practical IT use case.
Why Does Hybrid Work Need Layered Secure Access?
Hybrid work expands the attack surface because access no longer happens from one trusted office network. Users connect from personal networks, shared devices, managed laptops, virtual desktops, browser sessions and mobile endpoints. A single Virtual Private Network (VPN) or remote desktop gateway cannot cover every risk.
For sysadmins and IT security managers, priorities include reducing exposed services, verifying users and devices, restricting lateral movement and monitoring abnormal behaviour. Remote access should give each user the minimum access required, not a broad route into the internal network.
This is especially important for Windows Server RDP and Remote Desktop Services (RDS) environments. Indeed, exposed RDP, weak credentials and excessive administrator rights remain high-risk patterns. Secure access for hybrid work must therefore combine identity controls, access segmentation, endpoint checks, RDP hardening and incident response.
Establishing a Security Baseline Before Choosing a Tool
Before comparing remote access security software, establish a baseline. NIST SP 800-46 Rev. 2 remains a useful reference because it covers telework, remote access and Bring Your Own Device (BYOD) security together, not as separate silos.
Identity and Access Controls
Start with identity. Enforce Multi-Factor Authentication (MFA) for all remote access, administrator accounts and cloud consoles. Use role-based access control so users only reach the applications, servers and data they need.
Least privilege should apply to both human users and administrative tools. A helpdesk technician, contractor or finance user should not receive full network access because they need one application. This is where Zero Trust Network Access (ZTNA), application publishing and session-based access become important.
Device, Network and RDP Controls
Device trust matters because hybrid work includes managed and unmanaged endpoints. Require patched devices, endpoint protection and clear BYOD rules where personal machines are allowed. For high-risk users, restrict access to managed devices or isolated workspaces.
For RDP and Windows Server environments, avoid exposing RDP directly to the internet. Use gateways, browser-based access, IP restrictions, geofencing, account lockout policies and brute-force protection. CISA’s remote access software guidance is also relevant here because it focuses on securing remote access and remote administration tools, including risks linked to misuse and unauthorized access.
Patching, Monitoring and Incident Readiness
Secure access controls are incomplete without updates and monitoring. Keep all systems and apps up to date, as this will help keep them more secure. Log authentication attempts, failed logins, privilege changes, remote sessions and unusual connection locations. Alerts should identify brute-force attempts, unfamiliar countries, suspicious IP addresses and unusual session activity.
Incident readiness should include backup, ransomware protection, account recovery and rapid revocation of access. Hybrid work creates more entry points, so IT teams need controls which enable them to block, isolate and investigate quickly.
How We Compared the Best Secure Access Solutions
The solutions below are compared by practical fit, not by assuming every product belongs to the same category. The evaluation criteria are:
- Security depth MFA, segmentation, device checks, logging and attack protection.
- Hybrid work fit support for remote users, branches, contractors and BYOD.
- Windows and RDP fit : relevance for RDS, Windows Server and app publishing.
- Ease of administration rollout speed, policy clarity and operational burden.
- Scalability suitability for SMBs, mid-market teams and enterprises.
- Cost and complexity infrastructure needs, licensing model and admin overhead.
The result is a category-aware list. TSplus Advanced Security is not the same type of tool as Zscaler Private Access, and Cloudflare Zero Trust is not the same type of tool as Citrix Virtual Apps and Desktops The right choice depends primarily on the access layers you need to secure.
Summary Table: Best Secure Access Solutions for Hybrid Work in 2026
| Solution | Best For | Category | Strong Fit |
| TSplus Advanced Security (+ suite) | Harden Windows Server, RDP, gateways and remote access infrastructures (the suite adds secure browser-based access, app & desktop publication, web-enabling, granular BYOD + support and monitoring tools with SaaS potential) | Remote server security software, cyber protection, Zero trust (+ Application publishing and remote access) | IT Sys Admins, SMBs, ISVs, distributed teams |
| Cloudflare Zero Trust | ZTNA, web access and SaaS security | Zero Trust and SASE | Teams replacing VPN access |
| Twingate | App-level private access | ZTNA | Modern IT teams reducing network exposure |
| OpenVPN Access Server and CloudConnexa | Flexible VPN and secure network access | VPN and ZTNA transition | Teams needing network-layer connectivity |
| Zscaler Private Access | Enterprise ZTNA at global scale | ZTNA and SSE | Large enterprises |
| Citrix Virtual Apps and Desktops | Enterprise VDI and app delivery | VDI, DaaS and app virtualization | Complex enterprise environments |
| Venn | BYOD and contractor workspaces | Secure workspace | BYOD-heavy organizations |
| Splashtop Enterprise | Remote support and device troubleshooting | Remote support | Helpdesk and IT operations |
| TeamViewer Tensor | Remote support and device troubleshooting | Remote support | Helpdesk and IT operations |
Selected Secure Access Solutions
1. TSplus Advanced Security
TSplus Advanced Security is best positioned as a security layer for Windows Server, RDP and remote access infrastructure. It helps IT teams reduce common remote access risks through protections such as brute-force protection, geographic protection, ransomware protection, IP filtering, trusted devices, secure sessions, permissions and event logging.
This makes TSplus Advanced Security especially relevant for organisations already dependent on RDP, RDS, TSplus Remote Access or Windows application servers. Rather than replacing the entire access architecture, it strengthens the systems on which remote users already rely.
Pros
- Built for Windows Server and RDP security .
- Block brute-force attempts and suspicious login behaviour.
- Includes ransomware protection and session-focused controls.
- Configure your own zero trust secure access environment.
- Practical for IT teams with lean admin resources.
Cons
- Complete with Remote Access, Remote Support and Server Monitoring + MFA for a full set-up.
- Best used as part of a layered security strategy.
- Less suitable for organisations that have already standardised on large enterprise ZTNA platforms.
When to Choose TSplus Advanced Security
Choose TSplus Advanced Security alone when the priority is to harden remote access servers , especially Windows-based, protect RDP-based environments and reduce attack exposure without introducing enterprise-level complexity.
+ TSplus Remote Access, Remote Support and Server Monitoring
TSplus Remote Access provides secure browser-based Windows application and desktop access It lets organizations publish centralized Windows applications and full remote desktops, with users connecting through HTML5 or RDP-compatible clients. Advanced Security hardens its server and session layer.
For hybrid work, TSplus Remote Access frees IT teams from installing business applications on every endpoint. Applications stay centralised, while users access them from managed or unmanaged locations through a controlled remote access model which manages device-to-user locking, time and geographic restrictions and more.
TSplus Remote Support and TSplus Server Monitoring complement the suite. Remote Support provides maintenance, troubleshooting and training from anywhere tools, while Server Monitoring enables real time network and session surveillance and broader server and website management.
Highlight benefits:
- Supports HTML5 browser access, reducing endpoint client dependency.
- Reduces the need to expose direct RDP access.
- Enables you and your teams to watch, maintain and fix all your park from anywhere.
Choose the TSplus software suite when hybrid users need secure access to Windows applications or desktops from any location in all simplicity, especially where full VDI would be too complex or expensive.
2. Cloudflare Zero Trust
Cloudflare Zero Trust is a strong choice for organisations wanting to replace or reduce VPN access. Cloudflare Access is positioned as a ZTNA solution for employees and contractors across self-hosted, SaaS and non-web applications.
Cloudflare is particularly useful where hybrid work includes web applications, SaaS controls, secure web gateway functions and globally distributed users. It fits organisations that want cloud-delivered access policies close to the user.
Pros
- Strong ZTNA and web access model.
- Good fit for SaaS-heavy and internet-facing access strategies.
- Broad Cloudflare platform around access, gateway and security services.
- Useful for reducing dependence on traditional VPNs.
Cons
- May require architecture work for legacy private applications.
- Less focused on Windows Server hardening than TSplus Advanced Security.
- Can be broader than required for small teams with simple RDP environments.
When to Choose Cloudflare Zero Trust
Choose Cloudflare Zero Trust when the priority is to secure application access, web traffic and SaaS usage across a distributed workforce.
3. Twingate
Twingate is a ZTNA platform designed to reduce broad network access and give users controlled access to private resources. Twingate describes its model as a Zero Trust orchestration layer that integrates with identity providers, mobile device management, endpoint detection and SIEM tools.
For hybrid teams, Twingate is a good fit when VPN access has become too permissive. It helps IT teams move from network-level trust to resource-level access.
Pros
- Strong app-level private access model.
- Reduces unnecessary network exposure.
- Integrates with identity and device security tools.
- Good fit for cloud-native and hybrid infrastructure teams.
Cons
- Requires resource mapping and policy design.
- Not intended to publish Windows applications.
- May not address server-side RDP hardening on its own.
When to Choose Twingate
Choose Twingate when the main goal is to replace broad VPN access with more granular private access.
4. OpenVPN Access Server and CloudConnexa
OpenVPN remains a familiar option for secure network access. Access Server suits teams that want self-hosted VPN control, while CloudConnexa provides cloud-delivered secure networking and remote access with ZTNA and SSE capabilities .
OpenVPN is a practical fit when users still need network-layer connectivity rather than only application-level access. It is also useful for organisations that want a gradual transition from VPN to Zero Trust.
Pros
- Mature and widely understood secure access model.
- Access Server supports self-hosted control.
- CloudConnexa supports cloud-delivered secure networking.
- Useful for hybrid networks, branches and remote users.
Cons
- Traditional VPN models can grant too much network access if poorly segmented.
- Requires careful routing, MFA, logging and firewall policy design.
- Not a replacement for RDP hardening or application publishing.
When to Choose OpenVPN
Choose OpenVPN when network-layer access is still required, but pair it with MFA, segmentation and monitoring to avoid excessive trust.
5. Zscaler Private Access
Zscaler Private Access is designed for enterprise ZTNA. Zscaler positions ZPA as cloud-native private application access with user-to-application segmentation and context-aware policies.
For large organisations, ZPA can help replace legacy VPN patterns and reduce lateral movement. It is most relevant where global scale, enterprise integrations and centralised policy enforcement are mandatory.
Pros
- Strong enterprise ZTNA architecture.
- User-to-application segmentation.
- Suitable for global workforces.
- Integrates into broader SSE and Zero Trust strategies.
Cons
- More complex than many SMBs need.
- Requires planning, architecture and change management.
- Less focused on lightweight Windows Server hardening.
When to Choose Zscaler Private Access
Choose Zscaler Private Access when a large enterprise needs global private application access and mature Zero Trust policy enforcement.
6. Citrix Virtual Apps and Desktops
Citrix Virtual Apps and Desktops is a mature enterprise platform for virtual applications, virtual desktops and Desktop as a Service (DaaS). Citrix positions the platform for VDI, virtual applications and DaaS across cloud, on-premises and hybrid infrastructure.
Citrix is best suited to complex environments with advanced desktop virtualisation requirements. It can be a strong solution, but it usually requires more infrastructure, specialist skills and budget than SMB-focused alternatives.
Pros
- Mature enterprise application and desktop virtualisation.
- Strong policy, delivery and management capabilities.
- Suitable for regulated and complex enterprise environments.
- Supports hybrid infrastructure models.
Cons
- Can be complex to deploy and manage.
- Cost and administration may be too high .
- Not primarily a remote access hardening layer.
When to Choose Citrix
Choose Citrix when the organisation needs full enterprise VDI, DaaS or virtual application delivery at scale.
7. Venn
Venn is best for BYOD-heavy hybrid work. Venn positions Blue Border as a secure workspace for BYOD, where users work locally on their own computers while IT maintains control over work data access.
This model is useful for contractors, seasonal workers and organisations that do not want to ship corporate laptops to every user. It is less about remote desktops and more about isolating work data on unmanaged endpoints.
Pros
- Strong BYOD and contractor use case.
- Reduces need to manage the entire personal device.
- Useful where work and personal activity must be separated.
- Avoids some VDI infrastructure requirements.
Cons
- Not designed for Windows application publishing in the TSplus sense.
- Less relevant for server-side RDP protection.
- Best fit depends on BYOD policy maturity.
When to Choose Venn
Choose Venn when unmanaged devices are central to the hybrid work model and the organisation needs a controlled local workspace.
8. Splashtop Enterprise
Splashtop Enterprise combines secure remote access and remote support for hybrid work environments. It enables IT teams to provide attended assistance, manage unattended endpoints and give employees access to their work computers from different locations.
Security features include Single Sign-On (SSO), Multi-Factor Authentication (MFA), granular access permissions, session logging and IP restrictions. Splashtop Enterprise also integrates with identity providers and IT service management platforms, making it suitable for distributed helpdesk operations. .
Pros
- Combines attended remote support and unattended access.
- Supports centralized identity management and granular permissions.
- Provides session logging and security controls for remote connections.
- Suitable for distributed IT teams and hybrid workforces.
Cons
- Not a replacement for comprehensive ZTNA or network security platforms.
- Requires careful permission management to prevent unauthorized access.
- Licensing costs depend on access requirements, technicians and endpoints.
When to Choose Remote Support Platforms
Choose Splashtop Enterprise, TeamViewer Tensor or try TSplus Remote Support when IT teams need secure remote support, troubleshooting and device access, rather than application access alone.
Splashtop Enterprise is particularly relevant when IT teams need to securely access, maintain and manage distributed endpoints. Organizations combining employee remote access with centralised IT support will appreciate it, while those primarily seeking Windows Server hardening or application publishing are likely to look elsewhere.
Which Secure Access Solution Should You Choose?
The best choice depends on the access issues you face.
Where the priority is to protect Windows Server, RDP and remote access infrastructure, choose TSplus Advanced Security. If you also need to publish Windows applications and desktops securely through a browser, pair TSplus Remote Access with TSplus Advanced Security.
If the priority is to reduce VPN exposure, choose a ZTNA platform such as Cloudflare Zero Trust, Twingate or Zscaler Private Access. For enterprise-scale global access, Zscaler is the stronger fit. For leaner private application access, Twingate and Cloudflare are easier to evaluate.
When users still need network-layer access, OpenVPN Access Server or CloudConnexa may be appropriate. If the challenge is full virtual desktop delivery, Citrix is the enterprise name and TSplus provides the simple secure alternative Regarding the challenge of BYOD security, Venn deserves consideration. If the challenge is helpdesk access, use Splashtop Enterprise or TeamViewer Tensor with strict controls or simply switch to TSplus Remote Support.
Recommended Hybrid Work Security Stack
For many IT systems administrators, whatever the company size or the field, the strongest approach is often not one tool. A practical secure access stack for hybrid work includes:
- Identity provision with MFA and role-based access.
- TSplus Remote Access for centralized Windows application and desktop access.
- TSplus Advanced Security for RDP, Windows Server and session protection, time and geographic controls and ransomware response.
- ZTNA or VPN for private network resources that cannot be published directly.
- TSplus Remote support software for troubleshooting and patching use, restricted to approved technicians and embedded in your own platform.
- Logging with TSplus Server Monitoring, for real-time sessions data and central alerts.
This layered model avoids a common mistake: treating VPN, VDI, ZTNA, RDP security and remote support as interchangeable. Each layer should have a clear purpose. Or not be present. Any layer should also be monitored, restricted and reviewed regularly.
The best secure access solutions for hybrid work environments in 2026 are the solutions that reduce trust, narrow access and match the real use case. A hybrid workforce may need ZTNA, VPN, application publishing, RDP protection, BYOD isolation and remote support, but not all from the same product. Nonetheless, IT teams need it to remain simple.
TSplus Advanced Security stands out for IT teams needing to harden Windows Server, RDP and remote access infrastructure without the overhead of a full enterprise security platform. Combined with TSplus Remote Access, it gives you a practical path to secure browser-based access, centralised Windows applications and stronger remote access protection, with other TSplus products rounding off the provision.
