TSplus Remote Access is our flagship product. It is a remote desktop and application publishing solution. Indeed, thanks to this software, you can directly access your office computer from home. The same goes for any device for which you enable it. So for any member your staff and teams it is a PC-to-PC remote gateway portal: a software solution for remote work.
Software Solution to Enable Remote Work from Anywhere on Any Device
Remote Access Provides remote access to each workstation by its user from anywhere with an internet connection. All this is possible thanks to HTML5. Users can remotely log into their workstation using their credentials from a web browser on any device. When they access their desktop, it appears exactly as they left it the last time they logged in and worked, regardless of their location or the device they used previously.
TSplus Remote Access Software - a Solution for Versatile Team Mobility
Remote Access is a straightforward tool to enable home and remote work. This PC-to-PC remote gateway solution will grant employees direct remote access to their individual office Workstation. They can access it from their home PC or a shared workspace PC, from any laptop or tablet and even from their smartphone.
Affordable Remote Working Software Solution
TSplus Remote Access is the most affordable solution enabling seamless home working. Our software is scalable and adapted for use by SMBs to large corporations. IT teams will no longer need to fight for the right budget since such efficient and user-friendly a tool at a price that won’t scare off the finance manager is bound to please all parties concerned.
TSplus Software Solution for Secure PC-to-PC Remote Work
Users initiate secure remote connections to their individual workstation at the office with the login window. This is customisable to company colours. Thus, they can then work from their chosen location and on any device keeping a cohesive workplace feel. With our 2FA and Advanced Security add-ons, your company data and files are safe and benefit from 360° protection.
Access Desktops Via a Secure Single Sign-on Web Portal
The Remote Work Server gives businesses and organisations the ability to create a secure single sign-on web portal which acts as a remote desktop gateway. This means users can remotely access their office PC. Their credentials for the single sign-on Web portal will securely open the console session of their workstation in any browser.
PC-to-PC Remote Gateway Portal: Secure Solution for Remote Work Access
The server on which TSplus Remote Access is hosted manages connections between remote users and their office desktops. This gateway, as a web server, offers an easy-to-use and secure web portal. Companies can opt to self-host on-premises or in the cloud, keeping all their data where they want. This avoids exposing any information or files to the public.
I’ve talked in another article of the many advantages of enabling remote working within a business of any size.
TSplus Remote Access is a tool for that task which is easy to implement, affordable, secure and efficient.
To see for yourself our software's user-friendliness or any feature, you can Download or read more Now. So, why not use the software for up to 15 days for free before buying.
Further reading
HTML5 RDP Client
Read article →
