What is RDP and Why Are Port Numbers Important?
Before delving into the specific port numbers associated with RDP, it’s important to understand the protocol itself and why ports are critical to its operation.
Understanding Remote Desktop Protocol (RDP)
Remote Desktop Protocol (RDP) is a proprietary network communication protocol developed by Microsoft. It is designed to provide remote access to another computer’s graphical interface, enabling users to control that machine as though they were sitting in front of it. This capability is invaluable for IT support, system administration, remote work and troubleshooting, allowing authorized users to access servers, workstations, and virtual machines over a local network or the internet.
RDP operates on a client-server model, where the client (typically using the Microsoft Remote Desktop Client (mstsc.exe) on Windows or equivalent clients on macOS, Linux or mobile devices) initiates a connection to an RDP server. The RDP server is usually a Windows-based system running Remote Desktop Services (RDS) or a configured workstation with remote desktop enabled.
The RDP protocol supports a wide range of features beyond basic screen sharing, including clipboard sharing, printer redirection, file transfers, audio streaming, multi-monitor support and secure communication via SSL TLS encryption. These features make it a versatile tool for both home users and enterprise environments.
The Role of Port Numbers in RDP
Port numbers are an essential aspect of how network communication is managed. They are logical identifiers that ensure network traffic is directed to the correct application or service running on a system. In the context of RDP, port numbers determine how RDP traffic is received and processed by the server.
When an RDP client initiates a connection, it sends packets of data to the server’s IP address on a specified port number. If the server is listening on this port, it will accept the connection and begin the RDP session. If the port is incorrect, blocked by a firewall or misconfigured, the connection will fail.
Port numbers are also crucial for security. Attackers often scan networks for systems using the default RDP port TCP 3389 ) as an entry point for brute force attacks or vulnerability exploitation. Understanding and properly configuring port numbers is a foundational aspect of securing remote desktop environments.
Default RDP Port Number (TCP 3389)
By default, RDP uses TCP port 3389. This port is well-known and universally recognized as the standard for RDP traffic. The choice of this port is rooted in its long history within the Windows ecosystem. When you launch a remote desktop connection using mstsc.exe or another RDP client, it automatically attempts to connect through TCP port 3389 unless manually configured otherwise.
Port 3389 is registered with the Internet Assigned Numbers Authority (IANA) as the official port for Remote Desktop Protocol. This makes it both a standardized and easily recognizable port number, which has advantages for compatibility but also creates a predictable target for malicious actors seeking to exploit poorly secured RDP systems.
Why Change the Default RDP Port?
Leaving the default RDP port unchanged can expose systems to unnecessary risks. Cyber attackers frequently use automated tools to scan for open RDP ports on this default setting, launching brute force attacks to guess user credentials or exploiting known vulnerabilities.
To mitigate these risks, IT administrators often change the RDP port to a less common port number. This technique, known as "security through obscurity," is not a complete security measure but is an effective first step. Combined with other security strategies, such as multi-factor authentication, IP whitelisting and strong password policies, changing the RDP port can significantly reduce the attack surface.
However, it is important to document any port changes and update firewall rules to ensure that legitimate Remote Access connections are not inadvertently blocked. Changing the port also requires updating the RDP client settings to specify the new port, ensuring that authorized users can still connect seamlessly.
How Can You Change the RDP Port Number?
Changing the RDP port number can significantly enhance security by making your system less predictable to attackers. However, this change must be made carefully to avoid inadvertently blocking legitimate remote access. Here is how IT professionals can change the default port on Windows servers while maintaining secure and seamless connectivity.
Steps to Change the RDP Port Number
Open the Registry Editor:
Press
Win + RRemote Desktop Services (RDS) is a technology that allows users to access their desktops remotely.regedit, and pressEnter.
Press
- Navigate to the Port Number Location: Go to: pgsql: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Terminal Server\WinStations\RDP-Tcp
Modify the PortNumber Key:
Double-click
Port Number, selectDecimal, and enter the new port number. - Ensure the new port number does not conflict with other critical services on your network.
Double-click
Restart the Remote Desktop Service:
Run
services.mscfind Remote Desktop Services, right-click, and choose Restart. - This will apply the new port settings without requiring a full system restart.
Run
Best Practices for Choosing a New Port Number
- Avoid Well-Known Ports : Use ports that are not typically associated with other services to avoid conflicts and prevent unauthorized access .
- High-Numbered Ports : Opt for ports in the range 49152–65535 to minimise chances of collision and enhance security through obscurity.
- Document Your Changes : Record the new port number in your IT documentation to prevent connection issues and ensure all administrators are aware of the new settings.
Updating Firewall Rules
Changing the port number requires updating your firewall settings to allow incoming traffic on the new port. Failing to do so can block legitimate RDP connections.
- Windows Firewall : Open the Windows Defender Firewall with Advanced Security, create a new inbound rule allowing traffic on the selected port, and ensure it is set to allow both TCP and UDP traffic if needed.
- Network Firewall : Modify port forwarding rules on any external firewalls or routers, specifying the new RDP port to maintain access for remote clients.
How Can You Secure RDP Ports?
Even after changing the RDP port, maintaining security is crucial. A secure Remote Desktop Protocol (RDP) configuration goes beyond simply changing the port number; it requires a multi-layered security approach. Here are best practices to protect your RDP connections from attacks, ensuring robust security while maintaining convenient remote access.
Using Strong Authentication Methods
- Multi-Factor Authentication (MFA) : Enabling MFA ensures that even if credentials are compromised, attackers cannot access the system without a second verification factor, such as a mobile app or hardware token.
- Credential Guard : A Windows security feature that isolates and protects credentials in a secure environment, making it extremely difficult for malware or attackers to extract sensitive information, such as passwords or user tokens.
Implementing Network-Level Authentication (NLA)
Network-Level Authentication (NLA) requires users to authenticate before a remote session is established, effectively blocking unauthorized users before they even reach the login screen. This is a critical defense against brute force attacks, as it only exposes the RDP service to authenticated users. To enable NLA, go to System Properties > Remote Settings and ensure the "Allow connections only from computers running Remote Desktop with Network Level Authentication" option is checked.
Restricting IP Addresses with Firewall Rules
For enhanced security, restrict RDP access to specific IP addresses or subnets using Windows Firewall or your network firewall. This practice limits remote access to trusted networks, drastically reducing exposure to external threats. For critical servers, consider using IP whitelisting and blocking all other IP addresses by default.
Using a VPN for Remote Access
Establishing a Virtual Private Network (VPN) to tunnel RDP traffic adds a critical layer of encryption, protecting against eavesdropping and brute-force attacks. A VPN ensures that RDP connections are accessible only to authenticated users connected to the private network, further reducing the attack surface.
Regularly Auditing Open Ports
Regularly conduct port scans on your network using tools like Nmap or Netstat to identify open ports that should not be accessible. Reviewing these results helps detect unauthorized changes, misconfigurations, or potential security risks. Maintaining an up-to-date list of authorized open ports is essential for proactive security management.
How Can You Troubleshoot Common RDP Port Issues?
RDP connectivity issues are common, especially when ports are misconfigured or blocked. These problems can prevent users from connecting to remote systems, leading to frustration and potential security risks. Here’s how to troubleshoot them effectively, ensuring reliable remote access without compromising security.
Checking Port Availability
One of the first troubleshooting steps is to verify that the
RDP port
is actively listening on the server. Use the
netstat
command to check if the new RDP port is active:
arduino:
netstat -an | find "3389"
If the port does not appear, it might be blocked by a firewall, misconfigured in the registry or the Remote Desktop Services may not be running. Additionally, ensure that the server is configured to listen on the correct IP address, especially if it has multiple network interfaces.
Verifying Firewall Configuration
Check both the Windows Firewall and any external network firewalls (such as those on routers or dedicated security appliances) to ensure the chosen RDP port is allowed. Make sure the firewall rule is configured for both inbound and outbound traffic on the correct protocol (typically TCP). For Windows Firewall:
- Go to Windows Defender Firewall > Advanced Settings.
- Ensure an inbound rule exists for the RDP port you have chosen.
- If using a network firewall, ensure that port forwarding is correctly set up to direct traffic to the server’s internal IP.
Testing Connectivity with Telnet
Testing connectivity from another machine is a quick way to identify if the RDP port is accessible:
css:
telnet [IP address] [Port number]
If the connection fails, it indicates that the port is not accessible or is being blocked. This can help you determine if the problem is local to the server (firewall settings) or external (network routing or external firewall configuration). If Telnet is not installed, you can use Test-NetConnection in PowerShell as an alternative.
css:
Test-NetConnection -ComputerName [IP address] -Port [Port number]
These steps provide a systematic approach to identifying and resolving common RDP connectivity issues.
Why Choose TSplus for Secure Remote Access
For a more comprehensive and secure remote desktop solution, explore TSplus Remote Access TSplus offers enhanced security features, including secure RDP gateway access, multi-factor authentication and web-based remote desktop solutions. Designed with IT professionals in mind, TSplus provides robust, scalable, and easy-to-manage remote access solutions that ensure your remote connections are both secure and efficient.
Understanding and configuring RDP port numbers is fundamental for IT administrators aiming to ensure secure and reliable remote access. By leveraging the right techniques (such as changing default ports, securing RDP access and regularly auditing your setup) you can significantly reduce security risks.
