Banner for article "How to Install Citrix Workspace - Simpler Alternative for Remote Access", subtitled "A Step-by-Step Guide for Remote Access Users". Banner bearing article title and subtitle, TSplus Remote Access text logo, tsplus.net website, and illustrated by a picture of a smiling man at his desk, typing.
How Can You Install Citrix Workspace?
Step 1: Download Citrix Workspace
Visit the official Citrix download page and select the version appropriate for your operating system (Windows, macOS, Linux, etc.). Ensure you choose the latest stable version for the best performance and security.
Step 2: Run the Installer
Locate the downloaded file and launch the installer. Accept the licence agreement and proceed with the installation. If needed, you may choose custom settings, otherwise, proceed with the default configuration. For enterprise environments, the central step is to consult your IT department for specific configuration needs.
Step 3: Complete Setup
Once installed, open Citrix Workspace and enter the URL provided by your IT administrator. Log in with your credentials and access your virtual applications or desktop. If multi-factor authentication (MFA) is enabled, follow the prompts to complete the verification process.
What Are The Common Issues When Installing Citrix and How to Fix Them?
Installing Citrix Workspace can occasionally lead into complications, especially in environments with strict security policies or legacy systems. Here are some common issues and their resolutions:
1. .NET Framework Not Updated (Windows)
  • Issue The installer fails or shows a missing component error.
  • Solution Ensure that .NET Framework 4.8 or later is installed. You can download the latest version from Microsoft’s official website. Reboot your system after installation.
2. Firewall or Antivirus Blocking Installation
  • Issue Installation stalls or certain components fail to install.
  • Solution Temporarily disable your antivirus or firewall before installation or whitelist the Citrix Workspace installer. Re-enable protections after successful installation.
3. Insufficient Administrative Privileges
  • Issue Installation is denied or settings cannot be applied.
  • Solution Right-click the installer and choose “Run as Administrator.” For managed IT environments, contact your system administrator who holds the required privileges.
4. SSL Error or Workspace URL Not Loading
  • Issue After installation, the workspace URL fails to load or shows a security error.
  • Solution Check your internet connection and verify the validity of the certificate on your Citrix gateway and whether it is up to date. If using a proxy, ensure it is configured properly.
5. High Resource Consumption
  • Issue Citrix Workspace runs slowly or causes system lag.
  • Solution Close unnecessary background applications. Consider upgrading system memory or optimising Workspace performance through Citrix’s advanced settings.
Looking for a simpler alternative to Citrix Workspace?
Citrix Workspace is a robust solution, but for many small to mid-sized businesses, its complexity can become a barrier rather than a benefit. From licensing costs and infrastructure requirements to steep learning curves, many companies find themselves looking for a remote access solution which simply works, without the bells, whistles and complications.
That is where TSplus steps in. TSplus Remote Access is designed to provide remote desktop access and application delivery with minimal setup, affordable pricing and maximum reliability. It strips away the layers of Citrix’s enterprise-focused architecture to deliver the functionality growing businesses actually need.
Whether you are transitioning from Citrix or starting fresh, TSplus enables you to set up a secure, high-performance remote access environment in minutes rather than days or weeks.
Why Choose TSplus Over Citrix?
Citrix, while powerful, often brings with it a range of challenges:
  • High Licensing Costs Citrix charges per-user or per-device fees, plus additional costs for support and maintenance. TSplus uses a flat, affordable pricing model with a choice of perpetual licenses or subscriptions.
  • Complex Infrastructure Citrix requires multiple servers, extensive configuration and often third-party components to function optimally. TSplus can be installed on a single Windows server and quickly be up and running.
  • Difficult Upgrades and Maintenance Upgrading Citrix environments can be time-consuming and risky. TSplus offers easy, one-click updates and straightforward version upgrades as well as seamless silent rollout fixes where essential.
  • Steep Learning Curve Citrix administrators need certification and significant training. TSplus features a user-friendly interface that anyone with basic IT knowledge can manage. Additionally, the online TSplus Academy provides a self-paced and hands-on training platform for each TSplus product, with certification to boast your achievements.
  • Performance Bottlenecks Citrix relies heavily on network optimization and tuning. TSplus is optimized for performance right out of the box, even on modest hardware.
Key Advantages of TSplus
Ease of Use
  • Install in minutes with a clear, guided setup
  • Centralized web-based admin console
  • Publish apps or desktops with just a few clicks
Cost Efficiency
  • One-time license fee with no hidden costs
  • Multi-user support included at no extra cost
  • Free trial and upgrade-friendly licensing
Security and Stability
  • Built-in 2FA, IP filtering and endpoint protection tools
  • Compatible with standard Windows security protocols
  • Regular updates and long-term support versions available
Cross-Platform Access
  • Users can access apps or desktops via any device: Windows, Mac, Linux, iOS or Android
  • HTML5 web portal allows browser-based access without plugins
Scalability
  • Supports small teams to enterprise-scale deployments
  • Simple licensing tiers to grow with your organization
TSplus empowers businesses to deliver secure remote access and application delivery that just works, with no costly consultants or certifications required.
Installing Citrix Workspace can be a necessary step for businesses entrenched in Citrix ecosystems, but for many, it represents a path filled with unnecessary complexity and expense. By understanding both the installation process and the common issues that can arise, IT administrators can ensure a smoother experience.
Yet, for a more efficient, cost-effective solution for remote desktop access, TSplus offers a modern alternative built for simplicity and scalability. From SMBs to enterprise users looking to escape the high overhead of Citrix, TSplus is the go-to solution. Why wait to experience powerful remote access without the Citrix complexity with a 15-day free trial.
Further reading
HTML5 RDP Client
Read article →
